Recently I installed a 2K2 and speaker in a LGB Forney in the bunker. The sound is great, however there wasn’t enough room for the battery that was supplied, or a good place to put the switch for volume control. Without the battery sound really doesn’t function till you get to 6+volts so you loose all the startup with track power.
Which leads me to this… three Q’s (then probably somemore after these get answered)…First; Do you guys utilize the volume switch? Then …Second; If so where do you put it? And Third; Does Phoenix (or somebody)make a slimmer equivalent battery pack or a capacitor assembly similar to Sierra’s so I can fit it in the bunker. I went out to their website but didn’t see one.
Any help or ideas will be appreciated
Mark
