In keeping with the tradition that an ops session leads to rebuilding something, this year Pearce was a problem. Its been an issue in the past, with a tight curve (that I eased last year), and a grade (which got worse this year). So, it called for a rebuild.
I dug out and filled to make it as level as I could. Widened the curve, and moved the whole thing about six feet closer to the switch off the main. It also provided a good spot for a building I already had.
Here’s the area, not connected to the main yet, but leveled and ballasted with about 250# of aggregate.
Too hot to finish this up today. Maybe this evening Ill connect it to the main.
