Having absolutely no ability to draw on this confuser thing, I’m going to try to write a complete enough description that someone with talent can create a drawing from my explanation.
A couple of months ago, AndyC and I did some traversing of the old L&N line going southeast across Illinois. It is now reopened as the Evansville Western, a shortline. Our exploration ended in far southeast Illinois below and east of the town of Carmi at a place called the Pattiki(sp?) Mine. What a simple track scheme to model for operations, if you were using battery power and didn’t have to worry about polarity.
On a piece of paper, draw a circle occupying about 2/3 of the page.
Imagine it is a circle of track, with 12 o’clock being north.
At 6 o’clock install a left hand turnout, with the non-radius leg heading east.
At 3 O’clock install a right hand turnout, with the non-radius leg heading south.
Connect the tails of those turnouts at a wye, turning your circle into a “Q”.
The leg of the wye (tail of the “Q”), should continue away from the circle and connect with a main line track running across the bottom of the page, east to west and connecting to the “Q” with a right hand turnout that came at it in a southeast direction.
The collection point of two mines, that were a mile apart, was in the middle of the circle and covered by a very large cone or inverted funnel and an underground conveyor that went to a flood dump tower located at 9 o’clock on the circle.
Who says a person with a simple circle of track can’t have a realistic model railroad? The unit coal train came into the mine flood loading station from the main line trackage coming from the east. The train of empty coal cars ran around the circle, until the entire train was on the circle with the “Fred” being only 3 car lengths from the engines, when it was all on the circle of track. Andy and I didn’t see the loading, because it was getting dark and they hadnn’t started yet. But it is easy tio imagine that the train was loaded and then headed back out on to the mainline heading back east with a full load of coal.
A circle of track, 4 turnouts, a mainline staging track, too many coal cars and two or three diesel engines almost nose to the last coal car running on that circle and you’d be modeling a prototype operations.
