Given the parameters we seem to have been able to decipher from the Ames Super Gearing threads, I concede, given said parameters, gearing does not matter, if:
Current draw is of absolutely no concern.
A) You have unlimited current available.
B) Your pickups will not melt out.
C) Your control system will handle the current.
Top speed is of no concern if:
You can eliminate voltages at the top end by computer-enhancing the control system of your choice to remove any possibility of applying higher voltages.
Low speed is of no concern if:
You can computer-enhance your control system to have all control squeezed in at the bottom end, thereby artificially expanding the control in that sector.
Current use is of no concern if:
You have enough cooling fans in place to keep the motor cool.
You can enhance this with large heat sinks as necessary.
Theoretically, one could eliminate gearing altogether.
If the proper custom-wound motor is available, and the proper computer-enhanced control system factory-installed, the armature could be the drive axle.
One would have to design in dynamic braking (see: cooling fans) to slow this sucker down on grades, and I am certain some means could be devised to allow a train to wait on a grade without rolling away totally out of control.
Of course, motors as drive axles isn’t new.
Tried before (and failed).
