Last November, I threw together a rough “paint booth” for the Joe Douglass loco painting.
The filters are now clogged, and the box needs replacement. But here’s the design basis that I gathered from this effort, and will apply to something more reusable. Your preferences may vary, but here’s mine.
- Outdoor Vacuum Blower. Basically a blower that has a vacuum hose connection, and can operate in that mode. Some “bounce house” blowers seem to fit the bill, but I haven’t evaluated them.
For safety reasons, the motor has to be outside the airflow path. Fumes getting near the motor brushes are dangerous, due to ignition from sparks. And the paint coating on any electrical rotor or other contact areas can’t go on for long, I’d expect. I’m using, therefore, a high-CFM blower with its motor to the side, each with their own cases, and separated by the shaft bearing.
The blower can be portable, and the hose as well, and connected only when in use. In my circs, I already have an exhaust system for a laser cutter, and will just hook the paint booth up to that.
- Paint Booth Design. For model-painting purposes, the “booth” needs to be as big as any anticipated model. And if the model is bigger, it can go out in the dang garage.
Filters need to be easily gottable – like furnace filters. Maybe two or three, because the outer filter will always get trashed first, so a filter rotation should be workable. Any, use a standard size, maybe a size already used in the house, so if push comes to shove…
A “plenum” space is needed between the filter and the vacuum inlet, to get a better airflow of suction across the face of the filter. I chose a 2" gap, just because I needed to make a decision, and it seemed to work in the cardboard version.
There’s a million ways to keep a furnace filter 2" from a hose inlet. Discarded grille, fencing, rods, whatever. I chose a 1/8" plywood box, with its pieces lasered and glued.
The enclosure can be anything as well. For me, a plastic “storage tote” worked. This was after walking around Home Depot for an hour between their furnace filter and storage tote areas.
So, here’s the design model.
More to come…
888::>Cliffy
