Hi Bob!
I believe this is just a sheet of heavy aluminum that Fred had bent by a local metal dealer. The metal rails are fastened with self tapping screws directly to the turntable to eliminate the height of the ties. That height is taken up by the Lazy Susan bearing instead. That eliminates the need for a pit. This simple, space saving device is used at both Nelson and Ralph Yards and proven to be very reliable.
In the yard at Ralph there was a low semi-circular wall added to create the appearance of a pit wall. I suppose a semi-circle of rail could be added inside that wall to ensure the ends of the turntable remain perfectly level if a heavy locomotive like the K-27 was being turned.
Because of the all metal construction, this is suitable for battery powered railways only.
