As posted here:
http://www.bachmanntrains.com/home-usa/board/index.php/topic,5576.0.html
Mr. Ames writes the Optical Chuff Timer on the K, that has been touted as the most precise way to trigger chuff, may appear to be out of time-but it sounds right?..read below.
“If you use the optical chuffs for sound you may notice that the chuffs are slightly out if time which is exactely as most K27s actually sound.”
here is entire message:
StanAmes
Member
Re: sound systems
Reply #3 on: May 21, 2008, 11:17:48 PM
The installation instructions are correct and have had multiple installations. Each installation was approved by the respective manufacturer prior to its being posted. They can also mix and match the installation approaches as they are rather generic. I have a P5 in my K and it works great.
The reason your installer recommended a P5 over a 2K2 is because your AirWire receiver is designed to control a sound board that has a DCC input. The P5 has such an input.
Another alternative would be to use the QSI sound decoder together with the GWire receiver as this combination will also work with your AirWire system.
Hope this helps.
Stan Ames
