So the LA&C RR’s 2-6-6-2 #5 derailed off the high line dropping far into the gorge below. The loco took massive damage to the front and cab. While the loco was salvageable the tender was destroyed. In the market for another tender the LA&C found one for a good price. The trucks had been damaged but the shops had made the same repair before. Also, the tender being a bit small, they wanted to get a little more capacity out of tender so the shop started working upon it’s arrival.
After repairing and reinforcing the trucks the crew added an extension to bring the coal capacity up. Then they cut an old oil tank apart and added it on top to increase water capacity. This tender should give the rebuilt 0-6-6-2 #5 an extended range.
Honest thoughts on the build? Would it be plausible? I know the “it’s your railroad” thing but I try to follow prototype practices even if they are narrow gauge practices of a poor railroad.
Terry
