Latley I have been doing a ton of research on micro layouts. (Thanks to Vic he inspired me to start one). As far as what scale I decided to go with ON30. I really wanted to do G scale but the size I am going with would have been too small for the type of layout. Plus ON30 seems very affordable and the size is decent. Some of the key things I am going with
- size is 4ft by 3ft
- theme is logging
- Loop with a few sidings for operation
- Small trestle with a ravine
I went through many layout designs for ideas and I found pictures of this one.
http://www.freerails.com/view_topic.php?id=903&forum_id=40
I really liked the track plan and going to do something like this. This layout is 4 by 2. I have an extra 1ft wide to work with.
Working with Ho track is new for me. I picked up a few sections of 100 code nickle silver track and turnouts. I also ordered a Bachmann Porter from St Aubins for $33. For log cars I plan on making them using some old trucks etc… from my HO cars I dug up.
I plan on glueing the track down but not sure how to do the joints. In G scale you can solder or use clamps. Can the Nickle silver be soldered together? or just leave them alone? I am also going to paint the ties to look more like wood and probably take out every-other tie. Im starting with a sheet of plywood. Then I plan on using styrofoam on top. That way I can cut out my ravine and then any hills/mountains I figure I can just build up the styrofoam in those areas. Something like what vic did with his pizza layout.
Im looking forward to starting this project and having a small layout I can use indoors when it rains or is too cold outside. If anyone has an ideas or suggestions please post. This is all new too me. I will post my progress once I start. For now just trying to learn what I can.
Still check out the “shunting layouts”. Some of them still go in circles.
