So my ignorance of Locomotive design and function is really starting to show. Guess you don’t have to know how they work to love them.
I need to run the linkages from the Johnson bar to the two steam chests. As I started to do this I realized I have no idea how they are attached, or what they do really. I know when you push the johnson bar forward then the loco goes forward. When it is in the middle its in neutral and when you pull it back it goes in reverse. So does that just extend through a slot in the floor then hook to a rod that goes forward to a pivot rod that actuates two levers one on each side that pushes a rod in and out of the steam chest?
When I googled it I came up with a very scary all automatic sort of thing that was hooked to the driver that was very confusing. This is an 1880’s small loco. I think this would be as simple as it gets. So what should this look like?
Devon
