I understand that speed of the loco is controlled by the voltage applied, and that runtime is controlled by amps. At least, I think that is what I understand. At least, I accept it as axiomatic.
Now, let us assume an SD-45 from Aristo, with, say, 5 boxcars and a caboose. On the same level track, at the same average speed, which battery pack is going to give the longest run time, a 14.4V, 3200mAh or a 16.8V, 3200mAh battery pack?
Will the extra subC cells give a longer runtime, or is it only the mAh that controls runtime? One would think that with two extra “tanks” of fuel, one could get a longer runtime.
