Thank you all very much
This loco was running via an aristo 75 mhz onboard reciever. This summer I gutted the loco, took all the original LGB wiring out, and wired up the aristo reciever. I pulled the LGB 3 wires dealio and replace dit with two motor leads soldered to the motor, and two track power rleads soldered to the brass contact point son top of the brick. It ran fine for a couple months, then suddenly a couple days ago started this odd behavior
I took the motor out and tested it by itself on the bench. It seemed to run unevenly, So I thought ok, maybe it was damaged by running on an Aristo PWM throttle." So I happened to have a brand new replacement motor. I dropped that in, reassembled the loco, and it did the same thing. Same thing on my test bench as it did on my track.
I rewired the front headlight so it was powered directly from the track, with a bridge rectifier so that it was on regardless of track polarity. AHA! Power pickup is intermitent. But only in forward. That’s the part that seems puzzling to me. It should be intermitent in both directions, no?
Tonight I’ll tear it down again and check the power contacts inside the LGB brick. Resolder the connections. I can only assume there is some short in the brick which opens up when the brick torques a little in forward
