Ray,
I have yet to see a Buddy L which has brass driver wheel bushes. They do have the longitudinal brass strips as on the Heritage Express, but this is only to act as a buss bar to connect the leading and trailing truck wheel pickups to direct the power via the umbilical chord to the sound card in the tender and then back to the motor terminals. All my Buddy L have plastic drive wheel bushes and only pick up power on the pilot and pony wheels. An owner of a Buddy L, on another forum, assured me that his Buddy L picked up power on the drive wheel sets, so there may be differences in the production run, possibly at the time of changeover from Heritage Express to Buddy L. There may have been a surplus of brass bushes left over from the Heritage production run.
The addition of tender wheel pickups will see a vast improvement in power pickup reliability. However, with this reliability comes the inevitable other failures that this loco suffers from. I carry out numerous mods to my Bloody Ells and now have many hours reliable running time on them. They are now as reliable as the Annie. A useful mod is to remove the umbilical chord. This will disable the sound system, but will give better running reliability. The wheel pickup longitudinal brass buss bars in the loco chassis, will need to be wired to the motor terminals, if the umbilical chord is removed.
On my last Buddy L conversion, I discarded the original body and used a Bachmann Annie body (takes around ten minutes to modify to fit). At the time, I shortened the Buddy L chassis and the Bachmann body around 0.75" as I preferred the shorter look to the chassis. The shortening process is not required but was my preferred method as the Buddy L chassis appears to long aft of the trailing drivewheel set. I also used an Annie steamchest and steam cylinders with an Annie driverod connecting to the stock siderods. I also bonded a thin brass strip to the wheel tread on the centre driving wheelset. This brought the centre wheel diameter to within a few thousandths of an inch of the flanged wheelsets, improving the overall look. The end result was quite pleasing and suprisingly was very much like a standard gauge prairrie loco in Streamtown Museum.
