Wow. Just… wow.
As to that fine vehicle John posted, what could it be used for? Those look like rubber tires, and it’s sitting on dirt, so if it does not run on rails, how is it steered? That looks like a big leaf spring, so the fenders, with so little clearance, must not be attached to the frame. That cow catcher looks too flimsy to be of any use, and the cylinder looks too short for the stroke. Regardless, let’s throw an orange crate on it and go for a ride once we figure out which end is the front.
The rails are buried in the dirt, but they are there. There are fenders over the top and instead of a spring, I believe that’s part of the valve timing mechanism.
It’s use is as a tram loco. Just add a boiler.
John
I do also see the rails. I am sure the fenders are hiding flanges. The tires do look rubber. . .traction tires or bad lighting and they are really steel or iron. I also think the little wire cow catcher looks about useless.
Now the reason I asked John to dig it out is it looks very similar to Vic’s fireless dynamite rig (Can’t you see Wiley driving it) take the ridiculous cow catcher off extend the frame and put a wood beam pilot and it s easy to see. When John posted this awhile ago I couldn’t figure out why it was built as it was but it makes sense now. You put a boiler on that thing and a place to stand and you have a fireless loco.
There’s a lot a competent railroader could hang on that…
Yes they cross plumbed this from Vic’s, but it’s a start.
So this model was stretched slightly, but I’m sure a salesman charged for it!(http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-wink.gif)
Remember railroads were evolving, new and improved often meant Bigger and Better!
Happy Rails,
John
Back to Fireless … 'scuse the side track above…
Whaddya know? This cutie is down the road from me!
As I understand it; The water is super heated and as soon as steam is drawn off, the pressure is reduced allowing water to flash to steam maintaining the pressure until too much heat is lost.
This concept is so foreign… no really as ship yards were mechanized mobile cranes were needed…
John
Oh that crane is just wicked sick.
There was a fire-less locomotive parked on the South Side of Pittsburgh, back when I was in high school. I didn’t quite understand a stem locomotive without a firebox, but I guessed at how it could have worked. Later I found out that I was right. Somewhere I should still have some Poloroids of it.
Interestinve discussion. As it turns out this is a diesel locomotive. It was used at Lakeview Amusement Park (you can Google Lakeview Amusement Park and see a photo of this engine with 2 stainless steel passenger cars behind it).
There is a parallel blog thread at the following Trains Magazine web page if you would like more information.
Gee Jim,
Thanks for ruining it…(http://largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-wink.gif) it does explain a lot about why its streamlined. And it did open up an interesting conversation on a niche area of our hobby. Still would be fun to model none the less.
I like where we went better.
So did I, so much I’m thinking of bashing one of my lil haulers into an Apache Powder fireless cooker, just because
Well I was thinking that crane wold be a fun build.
Oh yeah! (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-cool.gif)put it at the Top of your list!(http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-laughing.gif)
Want some more… ideas?
yer bud
I’m soooo bad. Yet this one begs to be Amercanized!
A steam powered crane and locomotive. Crane pivots on stack, a 4 cylinder drive turns the crane. Drop the buffers and add a step pilot, open the cab some and there you go…
