Shawn,
You have the wires going in the wrong hole. In the instructions, para 4, It may not be clear to you. But in the front of the chassis, not in your photos, there is a small hole in front of a boss for a screw from the bottom plate, drill that hole open to 3/16", and continue downward so the hole is continuous through the bottom plate. The the wires follow the stainless are before entering the chassis. This way the wires add no tension or direction to the pilot truck.
In the meantime, I’ll see if I cn get a picture for you.
Barry - BBT
