Well, with the blessing of my better half (and the appropriate contra deal), I’ve finally bought a PLA printer. I got the Creality Ender3 V3 KE mainly because it was the cheapest one locally that gets hot enough to do the higher temp filaments (300/100 deg C). In theory…
So first Q: dialing in - I’ve just done white PLA, (temp, flow, PA), do I need to calibrate black PLA, or any other colour if it’s from the same supplier?
Second, no domestic issues with noise or smell using PLA on the kitchen table
- is PETG ok inside or should I plan to move the printer into the (cold) workshop now. I’m guessing that would mean an enclosure…?
Thirdly: Has anyone tried to print functional tie strips? ASA I guess would be the material. I’ve got the suspect AML track and it’s only a matter of time before the ties fail in the UV. At this stage replacing them is more expensive than the track cost when I got it.
Tks for your help.
Cheers
N
