Ok … I need someone thats a lot more savvy at this then I am…
Here’s the deal… I have a Dremel battery powered tool. Its got a 7.2Vdc removable clip in battery pack… 6 ea 1.2 V AA Ni-CD cells rated at 700mh. To recharge, the snap in battery pack is put into a charger base, that plugs into a standard wall outlet ( 110 AC US ). This pack is dying ( won’t hold a charge, short run time etc.) Time to replace it.
I can get Ni-MN AA cells with 1500mh rating w/tabs to replace the batteries, not difficult.
But… Will the charger work to re-charge the new NI-MN pack as is? If it can great… IF NOT, Then how would I go about re-charging the new pack? Or should I just go back to some higher mh NI-CDs? And would the charger handle the added load?
Thanks ahead of time…
Dave
