It’s been nearly 9 years since M-11 got it’s last electrical rebuild in March of 2012. At that time it was wired as selectable track or battery power (via trail car), Headlamps were upgraded to amber LEDs and a speaker was added under the front hood. Cabling was included to to connect power and sound lines to my sound/battery car “Shorty”. Here a a few shots from that major rebuild…
Four years later, I upgraded the couplers to Accucraft knuckles with a mounting method I fabricated in the shop from brass flat stock…
M-11 has been in service since, but doesn’t see a lot of action because I really don’t like the red color. I picked up a yellow cab and hoods years ago, probably from John Bouck, but I was lacking a black chassis. I advertised ISO a black chassis on Facebook’s G-Scale Swap & Shop group and Kevin Strong came through with a black chassis in great condition, but missing most of the removable details like ladders, steps and railings. This chassis has been sitting on my To-DO pile for several months, until now.
M-11 was completely disassembled, wiring cut out and parts organized. I replaced a few missing details on the trucks, then removed just the wire I had added from the track pick-ups. The trucks were then mounted on the black frame…
I have black ladders in stock, but no steps. The red steps were painted satin black using a method I use a lot at work for small parts: A wood scrap was coated with double faced tape, then the parts were stuck to it. The stick is long enough to hold outside the spray pattern and allows spraying from any angle. Lucky it was 50 and sunny today! This is what the steps and railing clips looked like just after painting…
Red M-11 had yellow railings. M-10 has black railings. I don’t want the hassle of painting rod, so they will stay yellow, at least for now.
I was able to re-use the track/battery switch as a On/Off-Charge switch. Not finding an easy to access place for the charge jack, I opted for center of the fuel tank…
A 5 amp fuse and MTO battery connector cable complete the wiring. The Yellow wire will carry battery power to a RailPro locomotive module. Looking at the other side, the original switch was maintained in it’s original location, just re-purposed…
There is still plenty of work to do. I haven’t ordered the RailPro module or battery yet so it will be at least a week until the chassis is running under it’s own power. Stay tuned!
