Greg Elmassian said:
Love to see more on their locos.
Greg,
I was asked to try to fix one for a friend not that long ago; a small German outline 2-6-2T. It’s a couple of years old, like I think all of them it was battery powered with a 7.2v NiCd battery and a fairly simple, 27mhz I would guess, r/c system; and when he bought it to me it wouldn’t work. I quickly established that the battery wasn’t holding a charge and replaced it with an NiMH battery, and it worked OK. We retired to celebrate, but hadn’t gone very far when it started smoking, but it has not got a smoke unit…
I quickly separated the battery and got down to causes; broken insulation on the battery wires shorting. There was no fuse on the loco that I could see. The rx/esc was still working so I installed a fuse, replaced the duff wiring and a couple of other bits where the insulation looked decidedly friable, reinstalled the 7.2v NiMH battery and the job was done.
(Lesson learned, BTW, is don’t assume the obvious problem is the only problem!)
I don’t still have the loco (he took it away with him of course) but from my observation:
a. The wheels, motion and mechanism are plastic, delrin by the look, but the loco tracked OK
b. It’s quite light and I’m not sure I would add much weight as I don’t know how strong the mechanism really is
c. But it pulled two Bachmann J&S and one Newqida coach up my 3% grades quite easily
Given my experience with this one I would certainly treat the electrics with caution, and before doing anything else would install a fuse, but apart from that for light service it seemed like a reasonable engine which is after all availabe at a very good price.
Steve
