Newbie question: Tunnel
Hello folks,
I had posted several months ago and several people had helped me build several passenger cars and recommeded Ridge Road Station whom I found to be very good. I have a favor to ask. I am not very handy building things :-(. I would love to be able to built a tunnel 36" length with standard G scale insides. Are there ready-made structures that could be bought? I would be happy to buy such a tunnel! Any recommedations would be greatly appreciated. I did look at the model power tunnel but they were poorly made of plastic (atleast the one I saw). Any suggestions would be great!!
Thanks folks,
Have a great Weekend!
-Saul
Saul will this for a inside or outside lay out?
Hi Saul,
there is the ever-the-same-problem thing with those structures: the “G”-scales goes from 1:32 up to 1:19 what makes it difficult to build such structures for a broad mass of customers.
BUT a tunnel is easy.
especially one with 36".
But there are different ways to build it, so i will tell u a way just to make a light and easy “hole”:
u need 3 boards of wood and 2 tunnel-portals like u can buy it everywhere.
for more u need a styrene-plate with 1 or 1,5 mm thickness and 36" length.
U have to draw the form of the portals to the boards.
Normally the portals have a sort of “inner ring” that allows to fit it to a bent styrene-plate.
U must now draw a second line on the boards, so that the later outcut tunnel-form has a distance of 2mm to the form of the portal.
Now cut the wood. Use 2 of the wooden forms to hold the bent styrene-plate to the tunnel-portals and use one of this forms to give the styrene-plate stability in the middle (u can make one more for that…).
Everything has to be glued together and painted with grey: ready is the tunnel!!!
A second way ist to repalce the styrene with wooden strypes 10 x 3 mm and fit them in one by one. Thats MUCH more work, but its easier in the end. Bending the styrene-plate and fitting the tunnel-forms is something where u always have to less hands free.
Frank
Thanks Frank! Much appreciated!
Geoff, this is for an outdoor layout! I live in the Pacific NW. So it does rain a lot :-)…Even before I rush out to pull my emergency buildings out!
Saul
Ok Saul.
Seeing that you are only doing a 3 foot long tunnel this should be easy.
You can get a BIG section of PVC pipe. I have seen them 2 foot across. Put that were you wont your tunnel and stack rock and dirt around it and on top of it. Your track will sit in the bottom and you should have tons of room for all your rolling stock to fit. Cut your own portals and your done. quick and easy. hope that helps.
Geoff
I built my tunnels using concrete blocks. If you want it to look like an unlined tunnel, you can texture the interior to look like blasted rock. If you want a timbered tunnel, you could build your timber structure and fit it between the blocks.
The corrugated PVC pipe is nice. but very expensive in the larger sizes. If you can get a small scrap piece from a job, like the one below, it makes a nice solid tunnel. This one is 24" but you don’t need that big.
(http://lsc.cvsry.com/Post/Pipe-03-640.JPG)
I’d recommend using a pipe of some sort with 12-15 inches ID. That way, you should be able to run even the biggest 1:20.3 stuff through it without scraping the paint. Most 1:20.3 users make the portal at least 12 inches above the rail top.
I run mostly 1:29, but from time to time a stray 1:20.3 wanders onto the property, so any tunnel I might make will have to clear JB’s K-27, if’n he ever gets it outta the shop.
If your scale is bigger than 1:20, just make sure that everything clears.
Paint the inside of whatever you use a flat black to help the illusion of reality.
Now, if you are running 1:20.3 Standard Gauge stuff, you are on your own. :stuck_out_tongue:
Simple tunnels can made using 2" x 12" pressure treated lumber to make open ended boxes. I used thin concrete block for mine -
(http://i113.photobucket.com/albums/n214/altterrain/new%20construction%206-07/tunnel2bridgeB.jpg)
-Brian
I did my like Brian’s using cinder blocks for the sides and some large paver stones on top. Then I put a heavy plastic overtop and piled dirt and rock on top.
(http://i31.tinypic.com/2058ldg.jpg)
This is what it looks like when finished off with portals and rock
(http://i42.tinypic.com/2rmv2w7.jpg)
wow!!! Thanks guys! This is really very helpful!!!
Thanks much!
-Saul
No problem Saul -
Thanks for the question. It gives us an excuse to brag about our stuff :smiley:
