Making progress on the new waterfall, learned a lot from the old one! This one has the rubber going up the sides some(2x6’s underneath) so the water is held in by rubber on the sides, not depending on the rocks/caulking to hold it on the sides as the old one did. Spill rocks are siliconed in, rest are dry stacked.
The filter unit will go up on top and hopefully be screened some by rocks/trees.
I like the two trees flanking the lower pond, may get some beside the upper pond later on.
The hose up to the top goes under the roadbed, in an old plastic downspout tunnel. You can see it to theleft of the tunnel as it comes out of the white plastic. This is hard work for an old retired guy!
