Hi all
I just bought the latest version of TrainOps the other day and have started using it. All seems to be going reasonably well, but was wondering if there is a way to reset it so it starts from the beginning.
What happened was I’ve been slowly working up my layout under the Physical Config, and testing it out. When I had things reasonably completed, I ran a couple of days through it, however now I want to start back at the first day. The reason is I use a place called “Fiddle” which is my storage shelves for all the rollingstock. This is set to be the yard tracks and I start all trains from here, so that TrainOps tells you which stuff to pull off the shelves and then run it to the locations specified in the Switch list. After a couple of days under TrainOps, I then want to return all back to “Fiddle” to represent that I’ve packed everything away. Does anyone know if this is possible?
Cheers
Tony
