Wendell and Barry, in this case hydrogen is stored in solid state, not liquid. This is relatively safe, the pressure at normal ambient temperatures 20-25 degrees Celsius is 8bar, which is just a bit more than on a typical live steamer boiler and comparable with that in the butane gas tank of our live steamer locos (warm water heated, at about 60 degrees Ceslius) and also comparable with pressure of pure propane at the same temperatures 20 degrees Celsius.
Horizon Fuel Cell Technologies sell two types suitable for toy trains: 10l storage and 20l storage canisters: http://www.horizonfuelcell.com/store/10l.htm http://www.horizonfuelcell.com/store/20l.htm full info is here: http://www.horizonfuelcell.com/file/MH-10_Metal_Hydride_Canister_manual.pdf You can use these to power your internal combustion hydrogen engine, burn the hydrogen to generate steam from water or use a fuel cell to generate electricity to power your electric motor. Horizon Fuel Cell Technologies only support the last of these applications and have a range of cell packs. Most more powerful ones are quite large, but for a typical electric toy train this 20 Watt 11 cell pack should work quite fine http://www.horizonfuelcell.com/store/h20.htm On their R/C car http://www.horizonfuelcell.com/hobby_rc.htm they seem to have used 30W 12 cell pack http://www.horizonfuelcell.com/store/h30.htm - this one should be able to power a K-27! It uses 300ml H2 per minute at peak power so you could run 33minutes on one full 10l canister and 66 minutes if you have 20 liter canister. Of course you can combine more canisters to run even longer. The times obtained from their specification 300ml/minute and 10l storage per canister must be optimistic as in their R/C car they give 65-70min maximum run time for 30liter storage (3x10l canister). If you need even more power 100W is the next one they offer http://www.horizonfuelcell.com/store/h100.htm If you require higher voltage, you will need to put two or more of these cells in series, but you would need to provide plumbing to deliver hydrogen to all cells at equal rate just as is done on each cell pack (internally). For more info on the current state of the art in hydrogen technology please check for example this source: http://www.ika.rwth-aachen.de/r2h/index.php/Hydrogen_and_Fuel_Cell_Technology#Transport_of_Hydrogen Best wishes from Tokyo, Zubi
Wendell Hanks said:
For Tom --Or? Is not one foible of hydrogen power is the extreeme pressure produced in the “hydrogen tank?” If my memory works, when applied to auto transportation, this pressure is toxic to those focused on automotive safety. If accurate, how does this translate to application in a model train? My guess is much more pressure than with a live steam loco – say the Accucraft models? Wendell
Barry Olsen said:
Maybe I’m missing something. […] The hydrogen is placed in pressurized fuel tanks at the “filling stations”, and just like the toy car the hydrogen is fed to the on-board fuel cell to generate the electricity for the electric motors which move the car. My point was couldn’t we do this same thing for our trains, a proper sized fuel cell on board the “battery car” replacement. Gasoline and hydrogen are nearly equally volatile, the difference is that the hydrogen rises very rapidly in the atmosphere, where gasoline is gravity driven (for lack of a more involved description). What is not addressed in all of this is the alternative of producing hydrogen to be burned in internal combustion engines (also possible, but I think less efficient). Barry - BBT
