I’ve not used just the Convertr on anything larger than a small 0-4-0 style locomotive (in which it works beautifully!). The Convertr is rated at 2.5 amps continuous, 16 amps (!) peak. With what you’re looking to do, I’d say you’re not going to tax the system. If you’re concerned about current draw through the Convertr, you can pair the Convertr with a Tam Valley Depot Booster. That will give you 3 amps continuous, 5 amps peak output to the decoder. (The booster has a circuit breaker that trips at 5.6 amps. I fuse all my installations at 5 amps as a matter of practice.) Early documentation on the Convertr didn’t list the 16 amp peak capacity, so I tended to err on the conservative side pairing it with the booster (or using Tam Valley’s DRS1 Hi-Power receiver). Knowing that now, I’d be more comfortable going with just the Convertr on installs such as you’re looking to do.
The Tam Valley DRS1 receiver gives you the same 3 amp continuous/5 amp peak that the Convertr/Booster would give you, for the same money as just the Convertr. (I just looked–they’re now selling for $89.95–cheaper than the Convertr!) The drawback to the DRS1 is that it’s limited to Airwire channel 16.
I’ve put the Convertr or Tam Valley Depot boards in 8 or 9 locos at this point, driving Tsunami, Econami, QSI, TCS, Massoth (LGB) and Zimo decoders. I’ve been very happy with how they work. (The K-27 in the video has the Tam Valley Depot board driving the Econami.)
One other option to think about… In one install I did for a friend, I put the battery, Convertr, and booster in the box car, and ran the output of the booster forward to the locomotive. He’s got a fleet of DCC-equipped LGB locos. On the locos, all I have to do is remove the track pick-ups and instead run a pigtail out the back of the loco to the box car. All he’s got to do is program the Convertr to the address of the locomotive (cab number), plug into the locomotive, and he’s off and running using the decoder already installed in the loco. I know you don’t have decoders in each of your locos, but it’s an arrangement to think about down the road.
One other thought. Since you’re using one decoder for multiple locomotives, you may want to consider the TCS WowSound decoder. They’re releasing a 5-amp version “shortly,” but I really like the 1.5-amp version I have in my 0-4-0. The advantage of this board is that it lets you save multiple presets on the board for different locomotives. I don’t remember if the presets cover motor and sound controls or just sound, but you can call up a given preset for each locomotive so not all locos sound the same. (With the Econami, you can also easily change the whistle and bell sounds, so it’s similar.)
