I have my first run at MU consisting working now. It requires physically setting up each locomotive using the setup switch but default direction and low speed crawling is completely configurable. I’m working on a method to allow PC upload of the speed tables to match locomotives. During the physical setup the locomotives in the consist are all given the same address. Loco setup takes no more than 20 seconds assuming the speed tables are already done. Figuring those out takes a while! I’m hoping to make an interface to load them easily at least.
At some point I may add on the fly consisting, allowing creation of locomotive groups. I would need to handle default direction for each locomotive while in the consist in the transmitter. I’m going to do consisting manually for a while to see how much interest the folks here have in it.
I set up part of the overall speed table for my Aristo RS-3 and SD-45 to work together. What wildly different locomotive speeds they have! Is the latest RS-3 version geared so high? The RS-3 is at least 2x as fast as the SD-45 at top speed. The RS-3 speed curve isn’t very linear either. I do have it creeping along with Back EMF though. For its weight it can drag around some cars at low speed now.
I’m going to equip my Bachmann 2-4-2 switcher again. It seemed to have a speed range and curve much more like the SD-45. That would look funny in a consist but what the heck. If that one goes well I guess I’ll start converting over all the locomotives I have.
