I was looking at Kevin’s article in Garden Railways Magazine on the various couplers, and it occured to me…
Nobody makes a glad hand that can easily be glued to the end of the existing Kadee trip pin.
Sure Ozark Miniatures makes a glad hand assembly that uses their rubber hose attached to an added fitting…,
But this is so simple and there are so many Kadee trip pins already in “non-operation” (in that they are not used for the intended magnetic uncoupling feature) such that the addition of a glad hand on the end can be bent up slighly to maintain the necessary track clearance without any other changes.
In addition to the actual glad hand fitting, the “kit” could include a cut length of heat shrink tubing to cover the trip pin and secure the glad hand. Those that are really fussy could add a piece of wire as a hose clamp.
This could easily be done on a 3-D printer. The idea is out there for the taking. Just send me the first set. ![]()
