The new version of the OMEGA-3 operating program is now available.
BV1 has been designed specifically for the TX-3, TX-5 and TX-7. It works by simply twisting the small knob either left or right from neutral and left there to select direction. It cannot be used with stick radios or the TX-20 that has a spring loaded direction change switch.
The BV1 does not have the controllable momentum like the AV1, but otherwise is identical, except calibrating mode happens instantly instead of having to wait for 6 seconds like the AV1.
AV1 is still available and is best for stick radios and the TX-20. AV1 can be used with the twin knobs TX’s but is a bit of a pain to use as the operator has to remember to return the small knob to neutral after twisting left or right before direction is actually selected.
I can reprogram older SMD ESC’s with AV1 but will need them back here to do so.
