Operations came to an end on the timesaver in 2008 after we decided to look for a more suitable house in the vicinity. The layout was dismantled and stored for better days. We found what we wanted and although the garden was smaller than before, it was much more practical to keep up and to display the bonsai collection, leaving more than enough space for a vegetable garden AND a decent layout. After moving and arranging the essentials for living in 2009, planning the new pike could start. The garden has a 10% slope so that had to be overcome by some terrain leveling in order to achieve a 2% maximum grade. I decided to work with a backfilled two level retaining wall and a winding track layout to bridge the 4 foot height difference. Here is a copy of the layout plan. It covers an area of approx. 27 by 30 foot
Work began in March 2010 with marking the grounds and construction of the retaining enclosure with “crack and stack” interlocking concrete blocks.
It took about 1200 of those to complete the wall.
The material is easy to use for a novice in building such as I and work progressed fast during the two following months.
By the end of April, backfilling could begin and some trackwork was laid. That involved another 18 tons of gravel to get up there by wheelbarrow…
By the end of May, this is what it looked like.
The first trains could test run a short distance in June
And the main loop was completed at the beginning of July, with the inaugural run on our Belgian National Holiday.
Meanwhile, most of the rolling stock has been converted to Kadee couplers and most of the locs equipped with Massoth sound decoders. There is still a lot of work to do but at least we can enjoy running our trains again! And as we found out that there is another model railroader (N scale) a few houses down the street, the pleasure is bound to be shared quite often.
