I got to looking at the cover of the new Garden Railways magazine and notice that the bridge on Rupert James’s railroad looks like cast concrete. This got me thinking about the use of concrete in our roadbeds.
Would it be advantageous to use precast concrete sections instead of casting the roadbed in place. I was thinking that you could control the casting better and it would save time in setting up the forms. Plus you could cast inside a shed or something and then place later. This would allow you to continue making roadbed even in the winter.
My idea would be making 3-4 ft sections depending on the weight of the finished cast. Cast lips in each end so you have something to connect the sections together. You could also cast in connecting points into the cement that allow you to connect the track to the roadbed. Then I would make a roadbed of base course. Tamp and level it and then place the concrete on that. I would glue the sections of concrete together with a concrete glue or paver glue. Or perhaps a silicon glue that would allow a small amount of flexure.
Anyways, just thinking out loud and wondering if it would work or not, your thoughts???
