Warren,
The vaccuum that you speak of is the Venturi effect, the same thing that creates lift on a wing. Airplanes really don’t fly, they are just sucked into the air. It has nothing to do with drag. Google “Venturi effect” for a more complete discussion than I can give.
The same thing occurs with ships when they get too close. Once, while I was conning USS Vincennes alongside USNS Cimmaron during a FAS (Fueling At Sea), an odd set of waves pushed one or the other of us, or perhaps both, into the Venturi effect, and the distance between us suddenly went from 150 feet to 90 feet and closing fast. It took some handy use of the rudder to break us out (full rudder at 20 knots only 90 feet from another ship will definately get your attention and increase the pucker factor, not to mention bringing all 4 sweat pumps on line!). Cimmaron by custom had to maintain course and speed, but I would not be surprised if they didn’t apply a little judicious use of the rudder, too.
Mike, I had a feeling someone was going to call me on that. I’m trying to remember from high school studies from longer ago that I care to admit! I’m sure that on this side of the pond we didn’t call it parasitic drag, though! My memory of that time resembles a moth eaten cloth. It was the 60’s, don’t you know!
If these locomotives are to be steamed at 100 knots or more (sorry), they probably should be aerodynamically streamlined. That means being designed by an aeronautical engineer, not a mechanical engineer. The ME can design everything inside, except the stuff needing an E.E., but the outside needs the A.E. If the windows are not going to be sucked out when two trains pass eachother at a closing speed of 100 whatever (mph, kph, knots), then they are either going to have to have beefier mountings, or the tracks will have to be farther apart to defeat the Venturi effect.
At one of my rare rail fan days, I saw a guy who was too close to the tracks get pushed away by the leading edge effect, only to have to fight being sucked into and under the train by the Venturi Effect. Spooky!
madwolf
