I built a steel fill in building years ago, I just painted it and placed a sign on it. The paint has faded and peeled off. So I wanted to give it new life, as many knows here I like working with magic sculpt.
I ordered, to try a new color, I had always used white and always painted dark for the first color.. So I ordered brown from amazon, It works great. I have always wanted to try to hand paint signs on the magic sculpt, so I tried that with very satisfying results. After getting the magic sculpt done, the front windows looked bad so I replaced them. The back, I tried the stucco/adobe style with very happy results.
#2 (permalink) | ||||||
Senior Member
The base to the sign for the front
#4 (permalink) | ||||||||
Senior Member
![]() Another Structure
I had another structure I built originally at the same time as the above one. I have been toying around with a method to paint a steel structure, would work on plastic or acrylic also. I wanted to paint a structure to represent wood type siding, steel structures are easy for me to build since I own a steel fabricating shop. Steel structures are long lasting if you can get it to look good. Just a one color of paint or powder coating does not work for me. As seen above I have done and perfected the Magic sculpt in several different types. I have used redwood siding added to a structure, and it works and looks very well. The methods I have used requires alot of time, and looks great, but I want to get maybe not great results but just good results, taking less time.
I now want to kick my butt for not taking pictures of this structure before I started, just imagine this has been sitting outside and looked pretty bad, peeling paint, lots of rust, So I cleaned it up and primed it, Then I painted it with a brown, then a kakie color, a lite tan, I did different wire brush methods to create brushing off the top color to expose the bottom color. Then taking a fine point sharpie, and a good variety of straight edges, I drew in the lines for the boards, nail holes too. I added acrylic shingles representing the shake shingle, and the signs.[IMG]
[IMG]
Closer up view [IMG]
[IMG]
[IMG]
