The crew has been busy building this engine terminal.
I’m using this to store engines . I ended up using one of Axels {Train - Li }5 way switches. He also let me use his rail bender . I ended up putting the switch inside the shed “keep switch out of direct sun light” I was told.So this is what I came up with.
Inside dimensions 3’ wide X 8’ long . I tried to make it look like it’s big brother!
Sean
