[This topic should perhaps be in the Power or Electronics forums - maybe I’ll but a note in there.]
One of the things I got for Xmas was a Tx20 kit from David Theunissen of Deltang (www.deltang.co.uk.) I had read about them when Tony Walsham started working with David on some small TX, and I figured I would give one a try. I had David replace his ‘momentary’ direction switch with an on-off-on switch figuring my live steamers need to be pushed into the right gear.
A little box of goodies turned up, and I spent a pleasant couple of hours assembling it. I have a small soldering iron and a magnifying glass - and a special soldering tweezer to hold things still (also a Xmas gift, via Micromark.)
Anyway, here it is sitting next to my C-16 tender that had to be opened to re-bind the RX.
Here’s the Tx20 next to my old DX5e. Some difference!
The buttons on top include a pair of momentary switches (trigger the bell, whistle, etc.) There is a red on/off with an LED in it, plus a Bind/ch 5 button. I’m only using the direction switch and throttle potentiometer mounted on the front, plus the on/off.
This is a small view of the packed internals. In the middle is the Tx2 board with 5 channels connected to the box’s switches.
It is working fine, although the Throw profile is set for 100% on ch 1 and 150% on the rest - I’d like 150% on all as I have a new 180 degree servo to drive my throttle on ch 1. I have instructions on changing to Throw Option 2 so wish me luck.
I wouldn’t actually recommend this to anyone. Since I bought mine, Tony at RCS has done a lot of work with David to optimize the unit for a live steamer, and he has added throw adjustment and other useful features. Buy one from him instead.
.jpg)
