For those who enjoy curiosity builds maybe this will get your juices flowing :
The second locomotive used at the 207th Street float bridge, would more correctly be referred to as a “work motor”, as it was electrically powered via the third rail. This locomotive is also referred to as a “drill motor”.
The following information is courtesy of the Trolley Museum of New York:
"Two were originally built by Magor Car Builders in 1930 for the IND 207th St. Shop. Equipped with Westinghouse control switches and trolley car high voltage type controller with dead man feature, they were numbered 41 and 42.
The Drill Motors were originally equipped with large spring loaded high voltage cable reels, mounted on the deck at the end of the car. The wire had a special clamp on the end which connected with the 3rd rail. This maintained 600 volt power to the Drill Motor allowing it to move off the 3rd rail and into the shop to couple up to the dead cars. The cars were then pulled out on to the 3rd rail. As the Drill Motor moved out, the cable would automatically wind up on the reel.
In 1948 the reels were removed for safety reasons and the Drill Motors were assigned to yard switching. They would make up refuse trains that were used nightly to pick up refuse from each station on the line.
The two large boxes mounted on the platform over the motor truck are filled with sand and scrap metal and were so placed to add weight and give the Drill Motor more tractive effort.
#41 and sister #42 worked the garbage collection trains on the IND system and were later used as yard switchers. #42 was involved a collision in 1948 and was placed in storage until 1955 at 207th St Yard, at which time it was scrapped."
Authors note: I have come across both 1930 (TMNY) and 1932 (www.nycsubway.org) build dates for these motors. Which is correct in unknown.
^ #41 - December 6, 1947 - 207th Street Yard, Manhattan, NY
Note float bridge gantry to left of locomotive.
unknown photographer
B. Russell collection
added 20 January 2010
^ #41 - unknown date - 207th Street Yard, Manhattan, NY
J. Testagrose collection
nycsubway.org archives
Info taken from: http://members.trainweb.com/bedt/indloco/nycta207.html
(https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-cool.gif)
