Bob…not too much there that interest me…
I was/am speaking in terms of a Large Scale Train Ele interface…Plug and Play-across the board-all manf (excuse the pun)…
As he bites his tongue - ‘Davey’ looks a bit of all right if into that sort of thing. The long caboose should find ready acceptance.
Cale,
Are you wanting the interface to be for large scale only & if so why?? The 8 pin socket can work in HO & N scale, but could be used in any of the other scales… There is nothing in the standard that says it will only work in HO or N scale… The Bachmann Porters that I have draw less than 1 amp, does that mean they need a large scale socket only?? What about the new 21 pin socket that Lenz is coming out with, should it be only for HO & N scale??
Bob Burton said:
Cale,Are you wanting the interface to be for large scale only & if so why?? The 8 pin socket can work in HO & N scale, but could be used in any of the other scales… There is nothing in the standard that says it will only work in HO or N scale… The Bachmann Porters that I have draw less than 1 amp, does that mean they need a large scale socket only?? What about the new 21 pin socket that Lenz is coming out with, should it be only for HO & N scale??
