I have created a problem with an AMS Combine that I hope someone can help with. While applying custom decals I spray painted some Rusto-oleum Clear Matte as instructed to seal the decals. The problem is I didn’t mask correctly and created a line on the body of the coach…to ad insult to injury I don’t believe I mixed the paint enough because of the whitish hue left where sprayed.
I’ve followed a few suggestions to gently sand with 320 - 800 grit wet/dry sandpaper the line created between the masked area and spray painted area. I’ve done this but the line is still somewhat visible and I’ve sanded away a little spot of the original green color on the car.
I feel I need to cut my losses and just repaint this particular side of the car but am not sure what paint or color to look for. The Combine is an AMS Unlettered in the Denver Rio Grande green color…very hard to find…darker than the CS car.
Any help is greatly appreciated. My other two coaches have turned out just fine because of a better masking job and better paint mix.
Thanks,
Richard
