Hi Guys
Can someone let me know if I have this right?? I have Llagas All. track code 250, number 6 switches, some where I read that the curve on a #6 is close to 16 ft dia. If this is right would a 16ft dia curve on the main line be correct to go with it? My thinking is the dia of the switch and main should match.
Another problem I have is the grade is around 5%, the area is about 110ft by 70ft If you where facing the area the lot slopes from left to right and back to front. The layout will be 1880s narrow gauge, the largest engine is a K27. Your thought’s please
Thanks Chuck
