Jon, The Rico station was an early era mid-west station. I used that as a basis for the design. That being said I designed this station as a partial rebuild.
In 1905 the LS ML & E needed larger freight facilities when the area of Lake Side became a vacation destination. Maple Leaf at that time was being served by two rails and was the closest interchange point for the extra traffic that Lake Side created. This turned into an extensive rebuild of the original station with a need for some corporate offices that were also moved to Maple Leaf at the same time.The original portion of the station is still evident in recent photos because of the stone kneewall facade on the passenger end ( still to be done ).
The upgrades were compleated in 1910 after the addition of a freight siding at the rear of the station and a regrading of the mainline. Since the station sits on the grassy knoll, track work can be arranged to suit. As I plan on a poured concrete style platform and not wood I can design as a car height freight side and a track height mainline side. Or I can make both sides car height.
Freight side was designed for car access under the roof so yes there is enough room with clearance.
Ric, Good idea on the water service at both ends. Can they both be spouts or do I need at least one tank? Also what about coal and sand?
Ken, Like the photos and the idea. Cheap and easy are good things and it looks like it will give the appearance I’m looking for. Like the idea of the stone wrap.
Bruce I like that style and I’ll keep it for the smaller Lake Side station, as that one will not be this large.
Ron, Hello nice to meet you
As explained above by building on the grassy knoll I can set the level either way, but I do like your in depth explanation of the reasoning in the area as it allows me some leeway in justification.
In the drawing I also added two extensions to the platform should they stay or go and if I use differant levels where do the ramped areas look to go.
The choice between concrete and foam is just portability. When finished I will have lamps on the platform. If it’s made of foam I can move the base also and store when not in use. If concrete the lamps will be exposed to whatever if the station is removed so I will leave it all in place and build a cover box.
Thanks again for the ideas and keep them coming .I’m learning as we go.
