From the “I wish I planned ahead department”. I built a trestle a couple years ago, and just recently decided to add a water feature under some of it. So the problem is that the trestle bents are not long enough and need some support. Structurally the bridge is strong enough, but visually they need some support. Not wanting to tear the trestle apart and make longer bents, I was thinking of casting some concrete piers under the bents. Not sure if that would be prototypical to have concrete piers holding up wooden bents, but it’s better than seeing them hanging there! I just returned from my snowbird summer to Florida for the winter, and started the water feature as soon as I cleaned up the dead leaves and weeds.
I’m looking for advice, ideas, suggestions on the easiest way to fix this. I was thinking of building forms around the bottom of the bents and pouring concrete piers. Anybody have any other suggestions? Easy fix? Here is a photo. The pond is done, the stream has only the first fabric/concrete layer done.
The water will be pumped from the trestle pond to a grist mill water wheel I built, then follow the tracks in a stream back to the pond. This is the future site of the mill, just carved the final layer of concrete. The hose is sticking up near the tree.
And below is the mill where the water will be pumped to come out in the sluice.
Thanks!
Mike
