5V regulator, capacitor across the output, heat sink, fits in a corner out of the way.
LED’s…use full battery voltage but a current limiting resistor, instead of the Kader current limiting transistors that won’t even cause an incandescent to glow…how much room do a couple of 1/8W resistors take? In the past, Bachmann has used seemingly indiscriminately 500 ohm and 1K ohm for the job…a guess would be whatever was cheaper to buy that particular day.
I see someone mentioned Bachmann Warranty. I need to send them a bill for cleaning the spewed coffee off my keyboard.
So, something quits.
You pack the entire thing up, ship it at your expense, they don’t know what to do, send you another. All your detail and custom road name lettering goes into the crusher on the loading dock.
You remove the source of what used to be most of the issues, i.e. circuitry failure (sorry, Bob…K-27’s with smoke units that wouldn’t turn off, class lights that wouldn’t turn on…all failed transistors, surface mount, ROHS complaint solder…) and you won’t have issue with that part any more.
If your components fail you know how to fix it.
Minatronics makes a neat flicker board…just wire in your LED’s, mount it in the firebox, connect up power, and you’re set. Now what do you have? Nothing but a speaker in the tender. Geez. What a concept.
Signing back off again.
TOC
