OK guys… ISO some help to re-wire three of these HF battery lights… into A strip of 6 of the LED strips wired end to end, [ linear strip ].
Powered by 4ea AAA batteries ( comes with the worlds worst cheap batteries).
Opening it up shows this:
and inside…
And the bottom of the switch circuit board…
So I traced out a schematic … pertty simple,but I don’t understand how to cut out the resistors or add enough, or what happens to put the six light strips in a long row.
I believe the 2 Led strips are wired in parallel …
I have 3 ea. 4 up AA battery cases [6VDC] output, that matches the 6VDC of the original light case, to use as a larger Mhr power source.
So could someone help me out in what I need as a wiring diagram, and what to do about the resistors in each of the original circuits , or how to wire up the lights…
I have lots of resistors and stuff to get it wired up, just don’t know what to do, to not burn the LED’s up…
