A freelance Garratt that I am ‘playing’ with. Uses two LGB #2017D drives.
VERY nice one, Tim! It has the feel of the real deal…
tac,ig & The Mount Hood Boys
Tim, Im interested in how you did your pivots and center framing. Do you have any more construction pictures of the garratt?
Doug, the pivot is simply a bolt (threaded section removed), bonded up from underneath the LGB moulding. The aluminium plate rides on a brass plate that reinforces/secures the upper side of the pivot shank, where it protrudes through the LGB chassis moulding. 0.030" styrene will then be used sandwiched between the brass and aluminium plates to reach desired height/clearance at the pivot join.
(http://freightsheds.largescalecentral.com/users/tim_brien/_forumfiles/1gscgf.JPG)
(http://freightsheds.largescalecentral.com/users/tim_brien/_forumfiles/1gscgg.JPG)
Very nice!
Mongo LIKE !!!
Very nice, Tim. Please keep the pictures coming.
Steve
any updates?
