My wife got her own engine to run at steam ups yesterday. An old Hyde Out Mountain Shay. I converted her from Sterno to alcohol firing using a flame pad for soldering copper plumbing pipe. Jim Sanders(weebee loco works)showed me this trick as he had converted a couple of his Sterno fired engines the same way. I put 4 layers of the padding in the belly fire pan and filled with alcohol to near the top. With the boiler filled to near the top of the sight glass, she ran for nearly 30 min till the fuel ran out, ending with the water near the halfway point on the glass. The side slung lubricator is unsightly, going to get with Jim about replacing it with a Roundhouse one mounted in the cab door way or relocating the stock one to somewhere better looking. Cylinders, reversing block and safety look to be Mamod items or clones of them. But unlike most Mamods, she runs really well, a slobbery puss with oil and water flinging off the crankshaft, but smooth and controlable with the RC set up that is installed, along with working lights front and rear. She is serial number 18 out of 102 produced(I am told). Trucks are heavy cast metal and sprung. She has Kayee couplers installed. Can’t wait for my railway to thaw out so I can run on the rails outdoors. Now my wife needs some small logging cars, either LGB or Hartland as the engines scale is around that size. Mike and Michele T
