I built this 1-1/2 inch scale caboose for my oldest daughter in 1980. She’s now 39. My son and I decided the car needed some TLC and a restoration. Because we are building seven Baldwin-Westinghouse electrics used on Pacific Electric here in So. Cal., we loosely based our restoration on P.E. Caboose #1975.
This is the result of thirteen months of restoration, sanding and painting, rolled out yesterday for a few photos.
The car has full working lights in the cupola and in the lower “office” area. The marker lamps are scale bronze castings from Railroad Supply Corp. As you can see there is a jumper seat for adult conductors and when that is removed, the grandkids can be “brakemen”. The cupola lifts off to get access to the electronics in the car. All leds are dimmable and have separate controls. There is a on-center off-on switch that turns all lights on in “HOLD” position and the other side is on a timer. When the timer is used, the lights come on automatically when the car rolls a few feet and they stay on during the run. When the car stops rolling, the lights remain on for another five minutes and then automatically shut-off. This photo was taken before it was repainted. Note the battery charger…I can use the same charger for this caboose as well as my Fn3 stuff.
