What you are looking at is about 50 by 55 feet. It is a folded wye, based on the Western Maryland’s Cheat Junction. What I wanted was a way to get from the outside yard under the deck to the inside storage in the shop. I think this has been fairly successful. The layout will continue on through the garden at the top, and is still to be determined. The stream will arise in a waterfall in the garden and terminate off stage at the lower right, only to be pumped back up to the waterfall. The yard at the bottom left is at 0 height, and works it’s way uphill to where it enters the basement at about 15 inches above the yard.
The indoor storage will be in the shop which in now just a daylight basement.
Any comments?
http://1stclass.mylargescale.com/SteveF/Layout%20Design/Cheat%20Junction1.bmp
