Having finished the sand house for the Mik early this year I turned my attentions to something I have always wanted to build, a water column. Still feeling the Spirit of Mik I raided my plumbing tote and went to work. I based my column on the European design since all the lifts and levers of an American one posed a challenge I couldn’t get my head wrapped around.
I think most of the bits I used are obvious. The valve at the base is a LGB spoked wheel with the flange cut off. The red counter weight is a drawer pull. The “sock” at the end is a piece of heat shrink tubing. I left the out pipe loose so it can pivot. The train pulls up, the fireman uses the chain to yank the pipe into place and turns the valve.
When the Spring arrives I will find a good spot for this in the Main Yard and screw it down.
