Tim , it is very possible to use a series parallel setup to allow more than a single speaker if you wish. I just finished an Aristo cab forward install with the Revolution with three speakers, one over each “engine” and a third in the tender for volume from a distance, if required.
It is important to understand that impedance IS NOT AN ABSOLUTE NUMBER. An 8 ohm speaker, for example will vary in impedance over the full frequency range, usually by a pretty good amount. If the speaker builder is reputable, then the rated impedance will be measured at or very near the cone resonance, and is ideally a minimum number.
Likewise your amplifier. Its rated 8 ohms is a safe minimum rating , based on presumed builder measurements, but is likely to be very safe from about 6 ohms on up.
There is no easy way to measure actual impedance ( or resistance at a specified frequency) in a home environment, so some of this remains educated guess work. However, it will not immediately "blow " your amp is you run a test with low initial volume. As you increase volume, if you hear problems too early in the runup, then you know you may have a problem. Remember, higher numbers means LESS current. Now, in a multi speaker setup, even though you have less power to each driver, you do have more conversion overall of electrical to acoustic energy going on. So , you will get more- or at least equal sound energy, assuming reasonable speaker performance, with good speaker drivers. Modern amp circuits are far more tolerant of uneven impedance loads than older technology.
Jonathan/Electric /steam Modelworks
