Nothing is perfect, all systems have their pro’s and con’s.
There’s a lot of good to say about MTH, but the DCS signal outdoors on a large layout is not one of them, and it has weaknesses that make it inferior to DCC for reliably transmitting commands. It’s no accident that MTH spent a lot of money adding DCC capability to it’s system, there is no arguing that, they did not spend the engineering resources because they were bored, or had extra cash laying around!
The other issue that makes it difficult to convert non MTH locos is the requirement of a tachometer on the motor, with the tachometer strip mounted to a flywheel and the optical sensor. Additionally, it’s not the motor speed that is desired, but the actual scale speed of the loco. This actually is very neat, because all MTH locos running at the same speed step are going the same actual speed.
In addition, knowing the actual speed of a loco allows you to have a cruise control and many other neat features. But this means the alternating black and white bands on the tachometer strip wrapped on the flywheel must be the right number to reflect the “gear ratio” between the motor rpm and actual speed of the loco. This translates to issues getting the right number of bands on the strip, which may be IMPOSSIBLE to achieve.
So, while the system and locos all work together well, converting other locos can be anywhere from difficult to impossible (no room to fit a flywheel) and expensive, and beyond the capability of the average hobbyist.
Indeed the addition of DCC to the PSIII is a great step forwards, but it’s not working 100% right now from what I am reading. This is probably just firmware and can be changed, but it’s going to take time.
Like I said, if I could purchase today the full repertoire of MTH locos with the PSIII I would be tempted, but right now there is far more for me in 1:29 and DCC where I can pick from many control systems from $150 (yes the NCE PowerCab complete 2amp system is $150) and decoders from many manufacturers.
This does not need to be a debate, like I said there are pros and cons to every system, but MTH is NOT the best, nor cheapest system out there.
Regards, Greg
