The circuitry is done and ready to drop in place. Additionally, the wires have been run between the floor and chassis for track pick-up and to let the relay kill the motor and plugs added. The relay only kills the motor and the as-built lights and smoke are unaffected. Additionally a flashing red LED was added to the rear of the railbus and hangs from the underside of the roof.
I changed the delay timing from 17 to 21 seconds (added 10 mfd) to better differentiate the idle from the start procedure, put a couple ferrite beads in the IC’s supply as well as 0.01 mfd on pin 5 to reduce potential “noise” from the motor and a reverse bias diode on the relay to reduce the BMF to the chip, not that these have been a problem so far. (But it hasn’t run with the motor on yet.)
I also added a 2.5 ohm inrush supressor to the relay contact that stops the motor, making the point-to-point start up bit easier on the internal moving parts.
The entire assembly fits on the floor of the railbus just behind the open doors. You have to look in on an angle to see it.
The speaker was trimmed down and fits up into the clearstory allowing the boards to fit underneath. The relay (raised) portion on the board assembly was put to the side so the hanging speaker clears it without problem. (Note the Motts speaker enclosure.)
Three switches control the operation. One dpdt, center off, turns on the delay feature in the up position. In this position the rear LED only flashes when the motor starts up and bus is sitting, but shuts off when the bus begins to move. In the down position, the delay is disabled, but the rear LED flashes when ever bus receives power. The LED power feeds from the green screw terminal on the relay and running at just 2.4 volts for the sound system to do its start up routine, no resistors are necessary.
The center switch controls the volume of the Phoenix board.
The other dpdt, center off, turns on the Phoenix AND connects the speaker in the up position. In the down position, the Phoenix connects, but the speaker is disconnected. This lets me charge the NiCad directly from the rails quicker because power is not lost to the speaker, and more importantly, I don’t have to listen to it while it charges nor do I need to play with the volume control to quiet it. This doesn’t seem to hurt the sound card either.
