Highly unlikely. I’m debating lighting the marker lights on the Obs, but that’s about it.
I got another short session in today while wife was shopping. Today was roof cutting day, so out came the mini-table-saw with the 80 tooth blade.
Didn’t quite fit - there seemed to be something the other side:
The belt sander was used to sand off enough to make them sit down on the body.
Once I’d checked the length, I turned the roof over, rechecked that it would fit the body, and started gluing it together.
Once it is on the coach, the side slots fit over the sides very tightly, so it’s only a question of not breaking the joint when I install it. Lots to do before that though.
After an hour or so, I flipped it over to see what sort of joint I’d have the fill and disguise.
Not too bad. Interesting that the texture on the top of the longer piece is different from the other parts.
